Hi All,
I am designing a canopy shade structure for a manufacturer to eventually be used in Florida and potentially other states. Its a 2 column design, the columns are spread 33ft apart with a cantilever shade extending about 11 ft out and with a curved fabric roof structure ranging from 6 degrees to 22 degrees. See attached for a simple diagram.
I conducted the components and cladding wind load calc and focusing on the uplift condition which would be controlling (D+0.6W ASD). With this the GCP for overhang perimeter is fairly high at -2.2. I am designing for a breakaway canopy system at 75mph so design wind speed at 105mph per Florida Building Code. I am ultimately getting 68 psf of uplift, which seems a bit high to me.
I have looked through the forum and ASCE 7-10 and cannot find a specific section that applies to these canopies. I am trying to value engineer it and my design seems to be a bit too conservative. Is there a reduction that I can consider that maybe I am overlooking? I do not think using the component & cladding procedure benefits me here. If I could use a field or even perimeter value for my GCP this would help, but technically I would say this should be an overhang.
Any suggestions would be appreciated! Thank you
