Stream Trap Selection Criteria
@ https://www.tlv.com/global/TI/steam-theory/trap-st...
Quote (TLV)
From the above article I cannot understand the bold criteria for selection
When installing a steam trap on a steam main, TLV typically recommends the use of traps that discharge condensate continuously, such as the Free Float® type. Other trap types such as disc, bucket, or balanced pressure thermostatic can be used provided that the collecting leg is adequately sized to prevent back-up into the steam main. Bimetal traps are not recommended for use on steam mains due to the possibility of large back-up distances which could pool condensate in the steam main itself. This is an especially worrisome situation when the trap is located close to the steam main.
What he means by collecting leg? What if I am sending condensates to open atmosphere?
Secondly large backup distances?
RE: Stream Trap Selection Criteria
The collecting leg is the steam condensate discharged typically from the multiple steam traps. And, the collecting pipe is routed to the condensate collecting tank.
As the steam trap is discharged to the grade (open atmosphere) without recovering the condensate, there is no condensate collecting pipe.
Quote (TLV)
Instead, properly sized, wider piping called a drip leg (collecting leg, or drain pocket) is typically installed to help enable the efficient and effective removal of condensate.
Good luck,
Latexman
Engineers helping Engineers
Thanks for replying. Can you please also elaborate why we cannot use Bimetal traps; I cannot comprehend TLV's reasoning may be because English isn't my mother language!
The goal is to remove liquid condensate from the steam main at all times. Bimetalic steam traps often operate as on off valves. They close when heated by steam and will open only after they cool down sufficiently by heat loss to the ambient environment. By the time the valve opens again, condensate will have collected in the pipe to the trap, and when this pipe is full there will no longer be any removal of condensate. Then condensate will move on down the steam main. So you must provide enough storage volume for condensate between the steam main and the trap, that condensate does not back-up to the steam main.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Strategies to Secure Connected Cars with Firewalls
White-hat hackers have demonstrated gaining remote access to dashboard functions and transmissions of connected vehicles. That makes a firewall a vital component of a multilayered approach to vehicle security as well as overall vehicle safety and reliability. Learn strategies to secure with firewalls. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - What is Generative Design and Why Do You Need It?
Engineers are being asked to produce more sophisticated designs under a perfect storm of complexity, cost, and change management pressures. Generative design empowers automotive design teams to navigate this storm by employing automation, data re-use and synchronization, and framing design in the context of a full vehicle platform. Download Now
eBook - Simulation-Driven Design with SOLIDWORKS
Simulation-driven design can reduce the time and cost of product development. In this engineering.com eBook, we’ll explore how SOLIDWORKS users can access simulation-driven design through the SOLIDWORKS Simulation suite of analysis tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
