Pre-cast Retaining Wall - Mass Concrete Base Design
Hi all,
We've been tasked with the design of retaining structures utilising precast 'L-shaped' wall element.
Ordinarily I would specify the pre-cast elements to be dowelled in to an RC base designed to resist the overturning moments and sliding.
In this instance we have been asked to prepare a mass concrete base option for these structures.
My initial thoughts were the following.
The pre-cast wall is dowelled in to the mass concrete
The overturning from the precast panel is resolved in to a tension force within the dowels in to the mass concrete
Sliding is resisted through shear transfer of the dowels
The resulting OM from the vertical and horizontal forces are resisted by the weight of the mass concrete foundation to achieve appropriate FOS
The sliding is resisted by base friction and passive resistance of the soils to achieve appropriate FOS
I'd be grateful for any thoughts on the above.
Neil
RE: Pre-cast Retaining Wall - Mass Concrete Base Design
Dont assume full passive resistance for sliding... ignore it or at least give a good factor of safety...
Thanks EireChch,
Other than that does that approach seem reasonable?
Neil
If you need tension ties at the back of the precast to prevent overturning then there will be significant bending moments in the base so it should be reinforced, not mass concrete.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
I have designed reinforced concrete retaining walls, but not precast walls dowled into an RC base. I will have a go regardless and some of the structys can correct me. Note, my opinion is based on my gut feel and nothing more...
The overturning from the precast panel is resolved in to a tension force within the dowels in to the mass concrete - I doubt practically you will get enough capacity in the dowels. Typically in an RC wall you have L bars that are lapped up the face and then returned back into the base. This is a good connection in my mind. But a number of dowels to resist overturning?? Not sure...May you can put enough deep dowels, at large diameter at close spacing but will this be practical. Also, is the overturning moment resolved into a tension force? I would think some portion of it will be but not a good chunk wont.
Sliding is resisted through shear transfer of the dowels - sliding will be resisted by the base friction as you have said below. The pre cast panel will receive some shear force at the connection which will be transferred to the dowels. I think that should be easily achieved.
The resulting OM from the vertical and horizontal forces are resisted by the weight of the mass concrete foundation to achieve appropriate FOS. The weight of the wall (stem and base) will resist overturning, but again will it be practical to rely on increasing the thickness of the the members to get the FOS. Increasing the heel length will give you more bang for your buck with the additional soil weight.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Integrating the Engineering Ecosystem
Aras Innovator provides multiple options for integrating data between systems, depending on the scenario. Utilizing the right approach to meet specific business requirements is vital. These needs range from authoring tools, federating data from various and dissimilar databases, and triggering processes and workflows. Download Now
Research Report - Simulation-Driven Design for SOLIDWORKS Users
In this engineering.com research report, we discuss the rising role of simulation and the paradigm shift commonly called the democratization of simulation. In particular, we focus on how SOLIDWORKS users can take advantage of simulation-driven design through two analysis tools: SOLIDWORKS Simulation and 3DEXPERIENCE WORKS. Download Now
White Paper - Industry 4.0 and the Future of Engineering Education
With industries becoming more automated, more tech-driven and more complex, engineers need to keep their skills and knowledge up to date in order to stay on top of this wave—and to be prepared for the Industry 4.0 future. The University of Cincinnati offers two online Master of Engineering degree programs designed specifically for practicing engineers. Download Now
eBook - The Design Gridlock Manifesto
In this eBook, you’ll learn 6 ways old CAD technology slows your company down and hear how design teams have put those problems to rest. “The Design Gridlock Manifesto” shares first-hand modern CAD experiences from 15 companies around the world. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
