neilquane
- Mar 7, 2016
- 3
Hi all,
We've been tasked with the design of retaining structures utilising precast 'L-shaped' wall element.
Ordinarily I would specify the pre-cast elements to be dowelled in to an RC base designed to resist the overturning moments and sliding.
In this instance we have been asked to prepare a mass concrete base option for these structures.
My initial thoughts were the following.
I'd be grateful for any thoughts on the above.
Neil
The pre-cast wall is dowelled in to the mass concrete
-The overturning from the precast panel is resolved in to a tension force within the dowels in to the mass concrete
- Sliding is resisted through shear transfer of the dowels
-The resulting OM from the vertical and horizontal forces are resisted by the weight of the mass concrete foundation to achieve appropriate FOS
-The sliding is resisted by base friction and passive resistance of the soils to achieve appropriate FOS
Neil
