Modfication in already FFS-III Assessed vessel
Hello
We have a vessel on ammonical water service as per ASME SECTION VIII DIV 1.
It was imploded due to vacuum. And was restored due to mechanical jacks and pneumatic pressure.
It was derated after FFS level 3 assessment.the study included details of all the welded patches in analysis.
My question is that now we are planning to install platform structure on that platform. For that we need to install few welded patches on external surface.
Its a cladded vessel with CS oitside and SS inside.
In past we have observed cladding detachment in vessel owing to imploded incident.
What hazards are anticipated in welding or installation of structure on vessel.
External thickness and DYE PENETRANT TESTING of surface is satisfactory.
Does it unvalidate The ffs study fea analysis. Or should we check after welding from inside.
Also the quantum of modification is very less in comparison. 200 x 200 plates 10 plates.
Or am i thinking more.
Best regards
Hassan
RE: Modfication in already FFS-III Assessed vessel
As I mentioned in the other post of this topic, any modifications to your vessel will immediately invalidate the original FFS.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Evolving Landscape of Commercial Battery-Powered Trucks
What’s driving the evolving landscape of truck electrification? What are the barriers, motivators and strategies for accelerating the electric transition? What insights and resources are available for today’s design engineers working to achieve industry disruption and evolution? For answers to these and other pertinent questions, read this white paper. Download Now
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
