Successful stratification strategies for balcony areas?
Two story buildings with the second floor open to the first. The second floor can get very hot. Esp. in the winter.
Do you have successful ways to keep the second floor cool short of cooling in the winter? (cooling while the first floor is heating)
RE: Successful stratification strategies for balcony areas?
The best way to handle that is to circulate the air keeping it all homogenized.
Keith Cress
You didn’t provide enough info to give any good answer. Sounds like there is only one thermostat and it’s on the first floor, which is open to the second floor and shares the unit. Where is the air supplied to? Where is the air returned from? Does the unit coil as well as heat?
Is the supply air from the floor or ceiling? Delivering air as low as possible will help during heating, but you may get the opposite problem when in cooling mode
You may not have the highest level of your space sealed, which in the winter creates a chimney effect drawing in cold air through the lower levels as the hot air leaks out the top
Ceiling fans run in reverse can also help mix the air better, but may not push with enough velocity to get the warm air all the way down to the first floor
You could put in an independent inline fan that comes on at the winter and draws in air from your high/hot point, and delivers it back down to the lower levels
Is your space intentionally open between the two floors? If easy to do you can seal it up and make it harder for the hot air to migrate up.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - PLM and ERP: Their Respective Roles in Modern Manufacturing
Leading manufacturers are aligning their people, processes, and tools from initial product ideation through to field service. They do so by providing access to product and enterprise data in the context of each person’s domain expertise. However, it can be complicated and costly to unite engineering with the factory and supply chain. Download Now
White Paper - Medical Device Design Control
Medical device product development is a highly integrated and regulated process. Implementation of a requirements tracking solution requires attention to a variety of nuanced topics. When presented with the task of tracking the many concept relationships in a project of this type, the initial software solution of choice tends to be a two-dimensional text systems. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
