I'm looking for a survey of peoples' experience with installing rock anchors in arctic conditions.
I'm of the opinion that due to QA/QC reasons alone, this should be avoided. Deep rock anchors will be located in what is essentially frozen bedrock, so good curing of the grout or epoxy in a very deep hole is nearly impossible due to the ambient cold temperatures in the rock, no matter how long you heat the hole for. This seems to me to require pull testing of every anchor. Some even insist on pull testing AFTER a full winter cycle, potentially delaying construction significantly.
HOWEVER... I see that it has been done, often even. So somebody clearly has no issue with it!
Eager to hear from all of you as to what I'm missing, your experiences, and anything else you might want to add.
Thanks in advance!
Thanks in advance!
