Development of multivariable function
margaritaklag
Marine/Ocean
GR
Hello! I am facing a difficulty into developing a multivariable function of a dependent variable "x".
Let's assume that "x" is a function of 6 independent variables a,b,c,d,e,f,g.
From experimental data i have developed 6 functions, each representing how "x" changes by each of the paremeters when the other 5 have a specific value.
So, what i have right now is for example: 1. x=f1(a,1,2,3,4,5)
2.x=f2(6,b,7,8,9,10)
3. x=f3(11,12,c,13,14,15)
6.x=f6(16,17,18,19,20,g)
What I need is to develop one single function of x where non of the variables will have a constant value.
x=f(a,b,c,d,e,f,g).
Any ideas or recommendations for where to look?
Thank you!
Haven't you essentially done that; x = f1(a) + f2(b) + ... where all your constants are replaced with fitting (now) unknown fitting variables? The only question is whether you have enough data to fit the 6+ unknowns.
TTFN (ta ta for now)
