Cutting F593 stainless steel rod
If I need to cut ASTM F593 bolts on site, what are the requirements for treating these after the fact? Can I get away with pickling only the portion that was cut?
*Eng-Tips's functionality depends on members receiving e-mail. By joining you are opting in to receive e-mail. Posting Guidelines |
RE: Cutting F593 stainless steel rod
If these are higher strength or a ferritic alloy then you would need to bake them after pickle to assure that you avoid hydrogen embrittlement.
