Populating Point Masses From Excel
Jeff Gibson
Aerospace
Jun 13, 2019
1
Hello all​
First post, long-time visitor. I am trying to find a way to populate point masses at coordinates (based on a picked CSYS) from an Excel sheet, and I'm doing this all from within ANSYS Mechanical. My problem is I have not found a way to count rows or directly call data from an Excel sheet. Should I just be using each coordinate as a parameter with the Excel import? That seems tedious.
I am not expecting a complete solution, but any pointers would be hugely helpful. I have experience with NASTRAN, FEMAP, and Abaqus, but ANSYS is totally new to me.
Thank you,
Jeff
Save the required worksheet as a comma-separated or Tab-delimited text file and use *VREAD or *TREAD to read in the data. I found *TREAD typically more useful as it doesn't require data format specifier.
