Wind load on Structural slab overhang.
I am designing an 11 story tower with approximately 120 ft in height and a wind speed of 175 mph. The tower is rectangular in size with around 90 ft in width and 250 ft in length. We are designing balconies on the width side of the building with a max of 13 ft cantilever. At the roof level, architects want to have a 20 ft over hang as the ceiling of top balcony. The height to height elevation is around 11ft.
I was discussing with my colleague as to what wind loads and directions to use. For the roof section (not overhanging) we used partially enclosed building asce 7-10 MWFRS with a 0 degree slop roof. This yielded us uplift forces and an overhang upward force in addition. However we discussed the approach of treating the 20ft cantilever as an open building design which yielded us upwards and downward pressures. The overhang slab is a structural concrete slab debating over RC or PT. There is a 3ft parapet right at the edge of the 20ft roof overhang. I wanted to know if any code treats overhang of that magnitude as an open building. I know in canopy design they account for upward and downward forces at base levels but not sure about downward forces at the highest elevation in the building. The Slab would be 0 degrees (no accounting deflection) tapered in the bottom face so as to reduce dead weight. I also wanted to know if there is downward load on the cantilever overhang, would I run a load combination of the upward load on the main roof and downwards load on the roof overhang simultaneously ? Wanted to see if any code accounted for excessive roof overhangs and or if there is a cut off length.
Any an all help would be appreciated.
RE: Wind load on Structural slab overhang.
For a building of that height and size, and an overhang of that magnitude, I would be very tempted to have it analyzed via wind tunnel vs. ASCE 7 wind parameters.
You are creating a wing, at 120ft , that's supposed to function in a cat 5 storm. JAE is right - you will have, possibly massive, second-order effects effects that will not be captured by ASCE - vibrations and fatigue might come into play as well.
Agree with JAE, for a 20ft overhang on a 120ft, ASCE 7-10 does not cover anything like that. Definitely hire a wind consultant and run tunnel test. The results are often multiple times higher.
I have used open building design in ASCE before, but the issue is that it assumes completely open, and no interaction with the solid wall face on one side, which sometimes makes things worse. Pardon my SI units, but I recently worked on a tower where I had gotten 1 kPa from roof uplift using ASCE 7-10 open building during concept design, only to get wind tunnel test results with 2.5 kPa later. I suggest not learning it the hard way I did.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Integrating the Engineering Ecosystem
Aras Innovator provides multiple options for integrating data between systems, depending on the scenario. Utilizing the right approach to meet specific business requirements is vital. These needs range from authoring tools, federating data from various and dissimilar databases, and triggering processes and workflows. Download Now
Research Report - Simulation-Driven Design for SOLIDWORKS Users
In this engineering.com research report, we discuss the rising role of simulation and the paradigm shift commonly called the democratization of simulation. In particular, we focus on how SOLIDWORKS users can take advantage of simulation-driven design through two analysis tools: SOLIDWORKS Simulation and 3DEXPERIENCE WORKS. Download Now
White Paper - Industry 4.0 and the Future of Engineering Education
With industries becoming more automated, more tech-driven and more complex, engineers need to keep their skills and knowledge up to date in order to stay on top of this wave—and to be prepared for the Industry 4.0 future. The University of Cincinnati offers two online Master of Engineering degree programs designed specifically for practicing engineers. Download Now
eBook - The Design Gridlock Manifesto
In this eBook, you’ll learn 6 ways old CAD technology slows your company down and hear how design teams have put those problems to rest. “The Design Gridlock Manifesto” shares first-hand modern CAD experiences from 15 companies around the world. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
