Cone Large End Not Adequately Reinforced!
The half apex angle is 54 degree > 30deg, How to reinforce the large end of cone?
Conical bottom head failed, showing the large end of the cone is overstressed.
How to find the solution to this problem
RE: Cone Large End Not Adequately Reinforced!
show us pictures and need more details during which process the failure occurred.
chicopee , Thanks I got the answer
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
