oengineer
- Apr 25, 2011
- 732
I am working on several Design of Steel Beams with Unreinforced Web Openings and I am having an issue with the vaule of two-thirds times the Plastic shear capacity of unperforated beam, 2/3 Vp,being higher than the Maximum nominal shear capacity at the location of an opening, Vm.
Basically, I am getting [highlight #FCE94F]Vm = Vmb + Vmt > 2/3*Vp[/highlight] instead of [highlight #EDD400]Vm = Vmb + Vmt < 2/3*Vp[/highlight]. I am not sure why I am getting this?
I am using AISC Design Guide 2.
Suggestions and comments are appreciated.
