Formwork Removal Time for RC walls
Hello everyone,
What’s the allowable period to keep formwork in place for a rc wall before adding fill and compacting. In this instance my wall is 4ft in height and 6 inches thick.
Thank you
Ganesh Persaud
RE: Formwork Removal Time for RC walls
As long as it takes to achieve the required strength. Compare your cylinder breaks to the required strength at the time of form removal.
Some people impose a minimum time such as 3 or 7 days, but that alone is not sufficient. Poor concrete at 3 or 7 days could still be poor concrete at 28 days.
There can be several answers depending on whats the Contractor wants to do:
1) If the forms are needed for reuse on a different length of wall, forms can be removed the day after concrete placement. However, the day old concrete should be covered and kept wet for a total of seven days so that it can continue to cure.
2) If the forms are left in place to provide the protection for concrete curing, forms can be removed after seven days.
3) For adding fill, wait until concrete reaches 90% of design 28 day compression strength.
4) For compacting fill, wait until concrete reaches 100% of 28 day design compression strength.
These are typical numbers based on my interpretation of DOT requirements for bridge construction. Other members may have different recommendations.
www.SlideRuleEra.net idea
@SlideRuleEra: are those DOT backfill suggestions specifically for R/C walls?
Great! Thanks for the reference. It's funny that it mentions "piers" because of a recent issue with a contractor. Contractor wanted to form the pier (bolting a casing down to the mat) and backfill, <24 hours after pouring the mat. He was pretty adamant that he could easily do it with no issues. My answer was still "no". Anyways, back to the original topic. Sorry for the digression...
skeletron - Glad the info was helpful. My understudy and I wrote a series of limited "mini-specs" based totally on DOT standards. Examples like a mini-spec for timber pile driving, another for steel piling, and a third for concrete piling; also reinforced concrete, structural steel, excavation and backfill, etc. We used these for in-house projects where, as the Owner, we did both design and construction management. Eliminated a lot of "boiler plate" and unnecessary language that did not apply to get Contractors to focus on what was important.
Hell, I see housing contractors here "getting away" with next day strip of basement wall forms and within a week are filling, but no compaction, no wetting of concrete either. Darn walls stay up. Not recommended, but who knows how close to failure they go. Of course in my many years I have seen them lean also, but rarely.
SRE, if you're interested in trading your hard work for little purple stars, I for one would love to see those mini-specs.
just call me Lo.
Lo - We did those mini-specs in the 1990's (pre-computer, for us) and never digitized them. I'll see if I can track down paper copies... if so, will be happy to make them available.
SlideRuleEra:
Good points for fill and compacting fill (sideloads) for a thin "wall" apparently comparable to the OP's questions.
I would recommend using the same criteria for points loads or embedded foundations in that wall: A handrail (sideways load for example) or structural columns on that wall for a roof or second floor need to be based on the concrete strength and surroundings at the specific time after pour the forms are removed or the structural attachment made. NOT the final 28 day geometry complete with adjacent walls and floors and supports, nor the 28 day cure strength.
Lo - Apparently did not keep a copy of any of our mini-specs when I retired. Did the next best thing, put together an updated draft of one as a sample... chose steel H-pile driving as typical (attached). We did a number of small projects from time to time that required just a few piling. Three examples:
pipe bridge for polyethylene pipe lines, 8 piling, (photos included)
conveyor foundations, 12 piling
transformer foundation, 4 piling
one more mini-spec to be added : "when You retire remind to keep a copy of all the mini-specs done all over the years" thumbsup2
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Engineering Report - Top 10 Defect Types in Production
This 22-page report from Instrumental identifies the most common production defect types discovered in 2020, showcases trends from 2019 to 2020, and provides insights on how to prevent potential downtime in 2021. Unlike other methods, Instrumental drives correlations between a variety of data sources to help engineers find and fix root causes. Download Now
White Paper - Addressing Tooling and Casting Requirements at the Design Stage
Several of the tooling and casting requirements of a part can be addressed at the design stage. If these requirements are not addressed at the design stage, lot of time is spent in design iteration when the design reaches the die caster. These design issues lead to increase in time and cost of production leading to delay in time to market and reduced profits for the organization. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
