FHWA gives guidance of a micropile attaining full head fixity at 24" of embedment. With a top plate attached and threaded bar/nut/ embedded into the pile, could the connection not be designed for fixity with a lesser pile cap embedment? Basically check that breakout on the bottom side of the plate/cap is sufficient to withstand the applied moment? Love to hear some thoughts.
