Lithium bromide chillers
zarnihein86
Chemical
MD
Three lithium bromide chillers are used in my factory.Now,we are running one chiller and then we occur cooling water and chilled water temperatures are high about 104F.How can i solve this.
These are absorption units and you are going to hire a mechanic familiar with them to diagnose and repair them.
Tell your boss that anything you are going to do will only make more problems.
First off you’ll need to get clearer on what your specific issue is. Is it the cooling water temp, the heating water temp, or something you are certain is specific to a lithium bromide chiller
Check with a specialist to do a proper water analysis to identify what is going on your absorption chillers.
it worth to check the vacuum pump if it working properly or not...
All the best
AB
