Dear All,
We've developed some new austenitic filler metals for ASME code work. No plans on getting it added to Sec II C. We have done many tests on our test heat and we are satisfied. The question is, for production of new melts, what tests should be done?
After reviewing code I see no clear direction on what the MTRs should contain for each new heat: UW-5 points to UG-4 to UG-15. UG-9 points to VIII, IX, and PQRs in general. VIII and IX appears to be only from vessel manufacturer point of view, not consumable manufacturer point of view, which is no surprise.
In past I see we had other proprietary metals with only chemistry analysis listed, some reports with more, which I questioned during our meeting. I believe this subject comes down to engineering judgement, what is your opinions here? I plan to request SFA 5.4 and 5.9 tests and supply my own criteria for each form.
Is there industry standards, technical reports, or a recommended practice on this?
