Diffrence between the coupling and MPC constraints
Hello All,
Can I know the difference between Coupling and MPC constraints in ABAQUS interaction tab.
your help is appreciated.
Kind regards,
RE: Diffrence between the coupling and MPC constraints
Coupling constraints are used to constrain nodes to a reference point. On the other hand multi-point constraints (MPCs) serve as constraints between different node groups. That's the main difference between these two types of constraints. Detailed description of each type can be found in the documentation.
If you can give some more info on what you modelling then we can give some more feedback
I have a question for this topic. I have a mass that represents an engine and it has to be attached to the fuselage (which is at the moment made of 1D beams). Is it better to create MPC or coupling?
You could use both but personally I would choose kinematic coupling. That’s because it’s more straightforward, general and easier to define. Effects, if applied correctly, should be ewuivalent. However I suggest to compare the differences between these two approaches in terms of what you want to achieve. You can also consider other types of couplings to avoid overstiffening the connection.
I will check both then, I've been used a mix of both for different components. I don't see major difference so far.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Simulation-Driven Design With SOLIDWORKS
Simulation-driven design can reduce the time and cost of product development. In this engineering.com eBook, we’ll explore how SOLIDWORKS users can access simulation-driven design through the SOLIDWORKS Simulation suite of analysis tools. Download Now
eBook - Integrating the Engineering Ecosystem
Aras Innovator provides multiple options for integrating data between systems, depending on the scenario. Utilizing the right approach to meet specific business requirements is vital. These needs range from authoring tools, federating data from various and dissimilar databases, and triggering processes and workflows. Download Now
Research Report - Simulation-Driven Design for SOLIDWORKS Users
In this engineering.com research report, we discuss the rising role of simulation and the paradigm shift commonly called the democratization of simulation. In particular, we focus on how SOLIDWORKS users can take advantage of simulation-driven design through two analysis tools: SOLIDWORKS Simulation and 3DEXPERIENCE WORKS. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
