LittleInch
Petroleum
- Mar 27, 2013
- 22,578
I've seen since I started in pipeline engineering some decades ago (cough), a requirement in construction specifications to avoid lining up the weld seams and offsetting them by a certain amount (this varies but is typically min 100mm or 10 degrees). My understanding of this has been that when seamed pipes were first mass produced, a number of weld seam failures occurred and the thought was that you didn't want to line up welds exactly to prevent long running fractures.
Now I have a situation where for a number of reasons I might not be able to do this and some occasions where the weld seam could align or be very close to alignment.
So the question is:
Given modern welded pipe production, is this still a valid concern?
Is the non line up just a preferred action or "mandatory"?
Have there been any failures where lining up the weld seams on adjacent pipes caused an issue / more damage
Is this requirement now out of data and just a hang up from the past?
This is for a liquid pipe at about 60C so I don't have the same running fracture properties you have with gas.
Design code ASME B 31.4
Pipe is 18" 5L X65 with wall thicknesses between 8 to 15mm
Your thoughts, links and past experience would be helpful.
I'm going to ask materials engineers, but they always tend to be a bit conservative and like I said at the start, this requirement has been around for a long time so maybe no one has really questioned it properly.
LI
So the question is:
LI
