Picking up a unbalanced load
4
I've got a object (a pre-cast, reinforced concrete frame/box combo) where the center of gravity is way off-center. Nowhere near the points where you'd think they would attach for lifting. How do I go about this? Maybe lift with a spreader beam (as opposed to the slings coming to a single point)? The object is about 60' x 26' in plan view.
RE: Picking up a unbalanced load
WARose,
There's a bunch of ways - spreaders and frames certainly work. You could also vary the sling lengths from the attachment point to the hook/spreader. How many pick points? Is there a vertical height constraint (i.e., object + rigging needs to be kept under a certain height due to crane restrictions)?
If you lift with a spreader beam, you could still have the whole spreader beam plus load tilting at an angle when lifted, which is presumably not the intended result.
Ideally, I'd locate lifting points in a horizontal plan, located so that the center of gravity is below the junction of the lifting points.
4
I've done this a few different ways in the past. No matter what you do, the center of gravity will align itself with the crane hook - so if you can tolerate the piece hanging skewed, you can keep your COG within the bounds of your pick-points and let it hang how it hangs so to speak. If you need to pick it up dead-flat, your hook needs to align with the COG - I've done this by using a custom lifting beam with offset top-lug as shown below.
Thanks for the feedback guys.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Research Report - How Engineers are Using Remote Access
Remote access enables engineers to work from anywhere provided they have an internet connection. We surveyed our audience of engineers, designers and product managers to learn how they use remote access within their organizations. We wanted to know which industries have adopted remote access, which software they are using, and what features matter most. Download Now
eBook - Managing the Context of Product Complexity Using the Digital Twin
Keeping track of changes to complex products is difficult—think Aerospace & Defense equipment, new generations of commercial aircraft, and software-based automobiles. A new way to managing the digital context of the physical product is required and the answer is the Digital Twin. This ebook explores the opportunity available for Operations and Maintenance for the Digital Twin. Download Now
White Paper - Trends in Industrial Filtration
Substantial progress has been made in filtration technologies in recent years. New filter media materials, designs and processes have led to filters that are more efficient, reliable, compact and longer lasting. This white paper will discuss the various trends that are impacting operational responsibilities of MROs today and the resources that are available for staying up-to-date on the latest filtration solutions. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
