Cooling tower exhaust separation distance from intake air
Hello all,
Appreciate your advise on avoiding air intake contamination from a nearby cooling tower exhaust. The intake , combined with exhaust, air louver for a building mechanical room is located within 10 m of the cooling tower exhaust (located on the roof). What would be your recommendation to best achieve the a higher separating distance (>10 m) between the two? If blocking part of the intake/exhaust louver : the air velocity would increase causing water penetration during wet weather conditions ; and if building a baffle around the cooling tower exhaust less heat transfer and hence less tower efficiency ? Please let me know you thoughtsponder
. Thank you
RE: Cooling tower exhaust separation distance from intake air
Not knowing all the features of the structures surrounding your office building and that of the cooling tower and the directions of the prevailing winds, I would explore increasing the inlet air duct to a different direction. Note that the exhaust from the cooling tower is primarily water vapor and air, so may be a dehumidifying system needs to be incorporated into the air intake of your building.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Strategies to Secure Connected Cars with Firewalls
White-hat hackers have demonstrated gaining remote access to dashboard functions and transmissions of connected vehicles. That makes a firewall a vital component of a multilayered approach to vehicle security as well as overall vehicle safety and reliability. Learn strategies to secure with firewalls. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - What is Generative Design and Why Do You Need It?
Engineers are being asked to produce more sophisticated designs under a perfect storm of complexity, cost, and change management pressures. Generative design empowers automotive design teams to navigate this storm by employing automation, data re-use and synchronization, and framing design in the context of a full vehicle platform. Download Now
eBook - Simulation-Driven Design with SOLIDWORKS
Simulation-driven design can reduce the time and cost of product development. In this engineering.com eBook, we’ll explore how SOLIDWORKS users can access simulation-driven design through the SOLIDWORKS Simulation suite of analysis tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
