Hello. We have an HVAC system originally aimed for thermal comfort only, and would like to use it for rooms that require HEPA filters.
The original fan is not suited for the higher static pressure required, so the idea is to install a limit-load in its place.
My question is: if I maintain the same flow through the evaporator (different operation point, higher static pressure), should I have any other worries concerning the system performance/integrity? Apart from noise.
