Fatigue Analysis with CATIA V5 FEA workbench
Is it possible to perform a Fatigue analysis with the Generative Structural Analysis workbench?
That is applying low-level load cycles and application of some metal fatigue theory.
I only see Static Case, Frequency Case, Buckling Case, and Combined Case.
There is also Static Constrained Modes, Preprocessing Case, Solution Case, and Envelope Case. I have no idea what those do but they don't sound like Fatigue analysis.
Frequency Case I believe only gives you the natural frequency. Very cool but that's not fatigue analysis.
Is there some module or license I need?
Is fatigue analysis only available in some other Dassault product, like Abaqus?
RE: Fatigue Analysis with CATIA V5 FEA workbench
I’m afraid that it’s not possible to perform fatigue analysis using CATIA. All these study types that you’ve mentioned refer to something else. You can only try exporting results from regular static analysis and postprocessing them to obtain fatigue life using another program. For low cycle fatigue Abaqus has special direct cyclic approach. Results from static analysis in Abaqus can also be imported to fe-safe which is Dassault Systemes’ software specialized in fatigue analyses.
3D Scanning in the Automotive Industry
With over 100 years of production history, the automotive industry has been at the forefront of manufacturing technology since its inception. Whether the transformative technology of the day was the assembly line, the integration of robotics into the manufacturing process, or the switch from steel to aluminum frame chasses, the automotive industry has consistently implemented advanced technology into its manufacturing and production workflow to improve manufacturing and product performance. Today, the same is true. Download Now
Green light on lidar: Developing low cost systems for autonomous vehicles
Lidar has been around for quite some time, but to date, it’s been custom—and expensive. Right now, there isn’t a clear-cut solution that’s suitable for all applications, such as lidar in autonomous vehicles. As they explore options, optical and mechanical engineers are forced to make choices and tradeoffs during the design process. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
