Remove screw from one family member
In a part(assembly) family I need to remove one of the screws from the assembly in some members (not needed in all members).
When i try to leave the replacement ID empty (see picture), the spreadsheet wants to remove these screws in all members, which is not wanted.
The family consist of different lenghts and 3 different sizes. For one size the screw is not needed.
Is there a way to remove this screw from some of the members without making a new family?
I'm using NX 12.0.1.7 MP2.
Thanks.
edit:
I found a work around, not the most graceful but it works.
I made the unwanted screws reference only and suppressed them by expression.
Then i updated the familie members that don't need the screw.
Undid the reference and suppressed state and updated the rest of the familie.
Then i released the parts so they can't be changed later.
RE: Remove screw from one family member
You don't need a work around, justo keep the cell empty like your image.
Don't use the apply option inside excel, just use create or update and save options.
Gelson Z. Nicoletto
Eng. Supervisor
Mould Desing
Brazil
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Strategies to Secure Connected Cars with Firewalls
White-hat hackers have demonstrated gaining remote access to dashboard functions and transmissions of connected vehicles. That makes a firewall a vital component of a multilayered approach to vehicle security as well as overall vehicle safety and reliability. Learn strategies to secure with firewalls. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - What is Generative Design and Why Do You Need It?
Engineers are being asked to produce more sophisticated designs under a perfect storm of complexity, cost, and change management pressures. Generative design empowers automotive design teams to navigate this storm by employing automation, data re-use and synchronization, and framing design in the context of a full vehicle platform. Download Now
eBook - Simulation-Driven Design with SOLIDWORKS
Simulation-driven design can reduce the time and cost of product development. In this engineering.com eBook, we’ll explore how SOLIDWORKS users can access simulation-driven design through the SOLIDWORKS Simulation suite of analysis tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
