MohdYaseen2010
Dears;
We have the following case;
Plant having first stage separator delivering the crude to the second stage separator, the second stage separator is directly connected to the high pressure export pumps (no buffer tank).
In my view the second stage separator shall be designed for external pressure (full vacuum) as it connected to a suctioning source (export pumps) while the first stage separator not required to do so.
Our Contractor is urging that there is no possibility of negative pressure inside the second stage separator (even its happen will be for seconds as the vessel operating pressure is high so the liberated gaseous will fill the gap inside the separator wherever the pump is operating).
1st Stage Separator (DP/OP = 2.2MPag/1.2MPag) & (DT//OT 125/65-100°C)
2nd Stage Separator (DP/OP = 2.2MPag/1MPag) & (DT//OT 125/65-100°C)
Export Pumps Centrifugal 170m (two flowrate cases one with 135m3/hr & other with 300m3/h) design temperature 80C
What Do you think.
Mohd Yaseen
What Do you think.
Mohd Yaseen
