re: Multi-Layer Elastic Analysis Software
All -
I used to use Everstress (Washington DOT) to review strains, stresses and deflections due to loading to model different scenarios for pavement rehabilitation, but, it is no longer available and the old version doesn't work on Windows anymore.
Any suggestions on free or commercial software that is relatively easy to use that will do multi-layer elastic analysis.
I also used Elsym in the way-back, but it was a DOS program... yikes. I think I also used Circly back then.
Any ideas? Cheers.
Any ideas? Cheers.
RE: re: Multi-Layer Elastic Analysis Software
I keep two older computers "alive" for just these issues. I have ELSYM5 running on one of them and Everstress on the other.
Huang's program is pretty good, just not very user friendly and a little quirky.
https://www.geoslope.com/products/sigma-w
Somewhere is my mountains of stuff, I have the ELSYM5 source code, written in Fortran. When I have nothing better to do, I'll probably try to port it to something Windows-based.
https://www.dot.state.mn.us/app/mnpave/index.html
Looks like MnPave uses MnLayer to do the LEA. I expect that other DOTs use similar free software for design.
Not sure if MnPave output give you stresses and deflections. If not, perhpaps you can contact Prof. Khazanovich (https://www.engineering.pitt.edu/LevKhazanovich/) to get a copy of MnLayer.
More info about MnLayer here:
https://www.researchgate.net/publication/245563024...
