adams/simulink cosimulation error
hello everyone
i'm getting this error while running a co-simulation in Simulink / Adams/car
the error says :
Error reported by S-function 'adams_plant' in 'untitled/adams_sub/ADAMS Plant/S-Function':
Adams model file Controls_Plant_1.adm does not exist! Check working directory. AEI_Initialize: Error in initialization.
1- I have set the matlab directory path on the adams directory path where it produces the m.file of my model as one suggested in a matlab forum ... but still this error persists
i'm sending you a picture of the MSC Software block in simulink and when i double click on it to chnage the animation mode , it is set on batch and can't be changed ...
thanks for the help
the error says :
thanks for the help
RE: adams/simulink cosimulation error
1.) Go "My Computer", right click and open "Properties" 2.) Go to the "Advanced" tab and click "Environment Variables" 3.) Create a new system variable, and call it ADAMS_CONTROLS_WTIME 4.) Set the value to something greater than the default, which is 5 (unit of time is seconds). The greater the value, the more likely it is that you will get a connection and not get an error, but the longer of a time you will have to wait for each and every simulation to run. 10 seconds seems to work best for me. 5.) Click "OK" a bunch of times, then restart MATLAB. You may need to reboot your whole machine.
- From Mathworks Forum.
exact same error popped up ...
hope you can come up with another solution ...
thank you very much for replying ...
I changed the value in step 4 to 10 and 20 seconds and exact same thing happened again also I changed the simulation time to the integers that you mentioned and still nothing and the same old exact problem comes up ...
"Adams model file Controls_Plant_1.adm does not exist! Check working directory. AEI_Initialize: Error in initialization."
so does this model exist?
Cheers
Greg Locock
and I have set MATLAB directory path on the Adams default directory path and the odd thing is that I can see the file ( m.file built by adams ) at the left hand side of my MATLAB window …
but when i run the Simulink model , although a simple one , this error pops up .
Cheers
Greg Locock
standard huh ?
this looks more sensible . i'll try it and keep you apprised . thanks alot for the effort and good responses .
I have the same problem.
Planet Export does not generate .adm file
Have you found a solution?
Not yet .I've been busy with something else but newbie user said something worthwhile …
you should take a look at it and you might even get to the solution before me …
i'll put a post here as soon as I get results but I expect the same from you as well …
thanks
I read newbie post completely and followed its instruct and get a result.
I ran a simulation with a specific name (for example "abs")
after that in planet export in prefix name, I put "abs_barke" (the name which generates by Adams solver at .adm file).
I would like to know if my work is correct or not.
it seems this is the best way since know!
yours sincerely
Sina
Were you able to run the co-simulation ?
Did you get the results of the Co-simulation along with postprocessing ?
what version of MATLAB and Adams are you using ?
