Uplift in spread footings
Looking for other interpretations of AASHTO LRFD 10.6.1.3 "Effective Footing Dimensions"...
It appears AASHTO allows a reduced footing for geotechnical purposes, but this will eliminate any uplift calculation...(since the concentrated force is now centered on the footing in the effective area)
When uplift on a spread footing is encountered, all AASHTO says in 10.6.1.7 is to "investigate for resistance to uplift and structural strength". So if the footing is structurally capable of resisting the uplift pressure and the footing is investigated for resistance to uplift (i.e. overturning is satisfied???) then is some uplift in your footing acceptable?
Thoughts?
RE: Uplift in spread footings
Theoretically, the footing shouldn't see any uplift because the SF keeps the net bearing pressure always downwards.
However, in practice, I have typically just distributed the hold down weight on the top of the footing and designed the top steel (in the footing) accordingly. It basically looks like a typical bearing pressure diagram.....only rotated 180 degrees.
Granted this is pretty conservative......but especially in a industrial setting.....the last place I want to tie their hands at is the foundations.
Yes, I think. If the uplift resistance exists (overburden soil weight, anchorage to a drilled shaft or pile, etc.) and the footing is structurally adequate for that uplift, then it can be accounted for in the design. The area that is in uplift is obviously not bearing on the soil below it, resulting in an 'effective' geotechnical bearing area that is smaller than area of the footing. That reduced area must be accounted for when calculating the bearing capacity of the foundation soil.
If the footing uplift is resisted, you cannot ignore the effect that has on the bearing pressure on the soil or the loading demands on the footing in shear and positive and negative moments.
I do not work with AASHTO, but from a purely structural analysis standpoint, a 1,000 pounds of uplift needs at least a 1,000 pounds of resistance to have a FOS of 1.0. We generally use 1.5 for working stress loads.
Highter and Anders (1985) presented some useful charts for 2-way eccentricity and effective area. I found them in Braja M. Das' textbook and it was a neat exercise to implement for spreadsheet use.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - How ESI is Helping Move New Medical Device Product to Market Quicker & More Cost Effic
Early Supplier Involvement has long been a strategy employed by manufacturers to produce innovative products. Now, it almost seems like a necessity. Because decisions made in the design phase can positively affect product quality and costs, this can help add value to OEM bottom lines. This white paper will discuss many facets of ESI, including why it’s so valuable today, what challenges limit the benefits of ESI, how cost is impacted, and more. Download Now
White Paper - Moving to a Driverless Future
This white paper describes what we see as the best practices to support a sustainable engineering process for autonomous vehicle design. It exposes how to use simulation and testing in common frameworks to enable design exploration, verification and validation for the development of autonomous cars at a system, software and full-vehicle level to drive a mature product development process for automated driving. Download Now
Research Report - How Engineers are Using Remote Access
Remote access enables engineers to work from anywhere provided they have an internet connection. We surveyed our audience of engineers, designers and product managers to learn how they use remote access within their organizations. We wanted to know which industries have adopted remote access, which software they are using, and what features matter most. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
