Has there ever been a study concerning the reliability of diesel pumps vs electric?
What I am thinking of is a hurricane prone area so let's say Houston, Texas.
Based only upon my observations over the years if a fire pump is down for mechanical issues it always seems to be the diesel pump the vast majority of the time.
If a diesel pump is down it's usually down for several days as repairs are made. Had once down once that took nearly a month to repair as getting the parts of the engine was a nightmare.
Hurricane comes through town taking the power out the diesel pumps will automatically start and run for maybe eight hours? What if it is really hot out, which it is right after a hurricane, and the vent/van doesn't operate because the electrical power is down? In any event the pump will operate for maybe eight hours before it runs out of fuel and, in a town as hard hit is Houston, refilling the tank is going to be at the bottom of everyone's to do list.
It sounds good, kind of like the 52,000 sq ft system rule, but has anyone every really done any studies on it? Since the beginning of time has there ever been an instance where a diesel pump has saved lives or property because the electrical power was down and the pump needed to operate?
I don't buy into the idea so convince me otherwise.
Oh, and I am not talking about a diesel/electric pump or a pump operating off a generator with auto transfer switch.
RE: Has there ever been a study concerning the reliability of diesel pumps vs electric?
Can’t plan for every disaster ??
And allowed only one at a time?
Fire department connection?
Scott that is a lot of good infromation.
First time I have seen that.
It seems to me that the reliability issue is one of the reasons the diesel pump to be a back-up system of the electric pump.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Addressing Tooling and Casting Requirements at the Design Stage
Several of the tooling and casting requirements of a part can be addressed at the design stage. If these requirements are not addressed at the design stage, lot of time is spent in design iteration when the design reaches the die caster. These design issues lead to increase in time and cost of production leading to delay in time to market and reduced profits for the organization. Download Now
White Paper - The Other Side of Design for Assembly
Assembly level constraints need to be satisfied before the design can move downstream. This white paper will go through the various assembly level issues, which need to be tackled by various organizations on a regular basis. Know more about DFMPro, a design for assembly software. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
