Heat Exchange Tube
Heat Exchange Tube
Heat Exchange Tube
In what case that the heat exchanger tube must be in welded and expanded? Or it is required to expanded? Please help to explain it
RE: Heat Exchange Tube
What material for tube and tube sheet?
How critical is seal?
How much thermal (and pressure) cycling?
In many applications rolled only is fine.
If you have a clad or overlayed tubesheet you must weld.
Acid coolers are welded because a leak is highly destructive.
And don't get me started on procedures, I can go on for a while......
Tube-to-tubesheet joints can be fully strength welded, partially strength welded, seal welded, expanded, or packed with a compression fitting. Tubes that are seal welded are normally expanded as well, but strength-welded tubes typically only require expanding to prevent crevice corrosion on the shell-side of the tubesheet.
Strength welds are typically specified to provide additional protection against leakage, but it some cases (e.g. fixed tubesheet exchangers, vertical floating-head exchangers) they can enhance the load-carrying capacity of the tubes.
Reasons for specifying welded tube-to-tubesheet joints include 1) to protect against interstream mixing of the shell-side and tube-side fluids, 2) to protect the base metal from corrosion for clad tubesheets, 3) to protect hazardous streams from leaking to the environment (first through the tubesheet joint then through a downstream gasketed joint), and 4) to enhance to load-carrying capacity of the tubes.
-Christine
White Paper - Effects of AIA Quick Guide to UL 489 or UL 1077
The function of a circuit breaker is to provide overload (thermal) and short-circuit (magnetic) protection to a circuit and its downstream components. A circuit breaker functions like an airbag in a car, protecting circuit components and people by tripping the circuit to interrupt the current flow if it detects a fault condition in the control system. Download Now
White Paper - Guide to Integrate Large-Format Additive
As with any new technology, getting into large-format 3D printing begins with investigation. The first question may be a simple one: what does “large-format” mean? For 3D printers, “large” is a relative term. Many extrusion-based (FFF) 3D printers are referred to as desktop machines, because they fit on table space. Some of these have very respectable build volumes – but when it comes to “large-format,” the machines will need their own dedicated floor space. Large-format 3D printers have significant build volumes and are most often found in professional settings, like manufacturing facilities and R&D centers. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
