electrod for welding cast iron to carbon?
Please tell me the electrode for welding cast iron to carbon steel.
If possible also share the reference
FOR ENGINEERING PROFESSIONALS Contact USThanks. We have received your request and will respond promptly. Come Join Us!Are you an
*Eng-Tips's functionality depends on members receiving e-mail. By joining you are opting in to receive e-mail. Posting Guidelines |
RE: electrod for welding cast iron to carbon?
https://www.practicalmachinist.com/vb/fabrication-...
What are the parts that need to be joined?
Regards.
DHURJATI SEN
https://www.nace.org/people/dhurjatisen
My best success welding cast iron is with an oxy-acetylene torch and cast iron rod. High preheat is a must, and the interpass temperature has to be maintained during the entire welding cycle.
The application must also be considered. Is the weldment subject to thermal cycling? There is no cookie cutter answer.
Best regards - Al
I need some reference of good website or company literature or some book.
Use Inconel electrode ENiCrFe3.
Regards.
DHURJATI SEN
