I am new in the realm of alignment methodology, techniques and fundamentals. I am interested to know about these terminology:
DBFF (Distance Between Flange Faces)
DBSE (Distance Between Shaft Ends)
Bore Tolerance
Face Tolerance
Appreciate if any of you experienced alignment hands could share your knowledge with some brief description of the above.
Thank you so much for the help!
Cheers,
James
Bore Tolerance
Face Tolerance
Cheers,
James
