Convert GSD spline to Part sketch
I used the GSD_PointSplineLoftFromExcel file to create a spline. It has imported into the part as a "GeometricalFromExcel" Object.
I can't move or edit the points or spline that were generated. My desire is to move this spline around as you would any line that you create in a Part sketch. I eventually will join this spline with other lines to create a bell. I do not want to create a wire-frame; which i understand is what GSD is used for?
Attached is a picture of what the specification tree looks like.
Thanks for the help,
Bob
RE: Convert GSD spline to Part sketch
Isolate the points and you should be able to move them as you wish. (Right click and Isolate)
"Isolate the points and you should be able to move them as you wish. (Right click and Isolate)"
I isolated the spline but was not permitted to move it.
drop the compass on the isolated geometry, when it turns green use it to move the object(s).
regards,
LWolf
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Understanding Critical Specifications for Dynamic Metrology Applications
Different types of metrology have different critical specifications to consider when determining which actuator technology to use. This white paper goes into detail on the demands of dynamic metrology applications as they apply to the selection of precision linear motion control components and systems. In addition, the relevance of Moore's Law is examined in the context of the industry. Download Now
White Paper - Permanent Non-Welded and Cold Bent Piping Solutions
Commonly used welded piping connections come with skilled labor, validation, inspection, and long commissioning times, as well as the workplace hazards associated with welding. Non-welded permanent mechanically attached fittings offer a viable alternative to welded piping systems that greatly reduces the time to commission piping systems through reductions in many of the time-consuming steps required in welding. Download Now
White Paper - Take Mobile Hydraulic Systems to a New Level
The introduction of digital ecosystems connecting electronic control hardware and software to the Cloud is catalyzing a new era of mobile machine and equipment design innovation. This is enabling OEMs across industries to develop customized solutions that digitally integrate hydraulic and machine controls with the Internet of Things (IoT). Download Now
White Paper - The Evolving Landscape of Commercial Battery-Powered Trucks
What’s driving the evolving landscape of truck electrification? What are the barriers, motivators and strategies for accelerating the electric transition? What insights and resources are available for today’s design engineers working to achieve industry disruption and evolution? For answers to these and other pertinent questions, read this white paper. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
