Contact US
Formally noting on a drawing to marr exposed bolt thread?
Hi all,
I have recently designed some steel supports bolted to ex. concrete for electronic signage at a train station. Client is concerned about people stealing/tampering with the exposed nuts on the epoxied anchors - I am not too concerned but have suggested that we specify Loctite 263 (~permanent thread locker). They have come back and suggested marring the bolt threads above the nut as a 'permanent' solution. I have specified this approach in the field before but never as a notation on a formal drawing - looking for input on how to specify this (or if it is even necessary). Thanks!
RE: Formally noting on a drawing to marr exposed bolt thread?
cadialg, have seen / done similar. Drawing note, "peen" or "stake" exposed threads, words to the effect.
Put it on the drawing only if you want it done :)
Mike
"Peen exposed threads after torqueing to xxxxd.x foot-lbf. Then prime and preserve per Note yyyy of Spec zzzz."
Hi
Try using vandal proof nuts or make some, these consist of a smooth spherical shape body with a threaded hole and at one end have a small hexagon section which allows tightening to a pre-determined level at which point the hexagon section breaks off the threaded sphere.
see this link:-
https://www.bolt.com.au/stainless-steel-vandal-pro...
The railroad industry requires that bolt threads are "chisel checked or tack welded" after torquing. This is actually an AAR regulation to prevent loss of the the nut on threaded connections. Of course the chisel checking doesn't prevent initial loss of clamp load, but it makes the powers that be feel good.
Well, let's recognize that in some situations loss of the fastener is far worse than loss of the preload.
Mike
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
