Effects of reduced major diameter of a bolt on the nut? 1
TylerClimber
A supplier conducted a proof load test on a nut, using a test bolt whose major diameter is .004 inches smaller than the original requirement. Does having a smaller major diameter (while keeping everything else the same) reduce the stress on the bolt and increase the stress on the nut? This means that with a smaller major diameter on the bolt, a lower tensile load can be applied in the test without causing the nut to fail, correct?
Edit: my initial wording was off, I meant that with a smaller major diameter on the bolt, the forced that's required to fail the nut's thread is now decreased.
"0.004 inches" on a #8-32 or on a 1"-8?
Do you think the difference matters?
Mike
the proof load test is a tension test?
what failed first, the bolt or the nut?
are you referring to the major diameter of the bolt thread area? or shank area?
with a smaller major thread diameter on the bolt, and a failure in the nut, then the test is likely conservative. if it failed in the bolt, then the test may be unconservative for the nut.
SnTMan,
On a M6-1.0, I think its pretty significant for fasteners this size?
SWComposites,
Yes, tensile load. No failure yet, but the goal is to fail the nut, the bolt has a higher UTS.
Major diameter of the bolt threaded area. So I guess I was correct earlier?
If its just a proof test to a defined load, and they achieved that load, then there should be no problem. If anything its a conservative test of the nut.
The "major diameter is .004 inches smaller than the original requirement. "
Was that "requirement" based on a standard like ISO 965 (?) etc?
Is the pitch diameter within ISO tolerances?
Hi Tylerclimber
0.004” down on the major diameter of M6 external thread is still within the normal tolerance range for a thread standard see this link :- so I doubt there will be a significant effect on the bolt strength. Why do you want the nut to fail first?
