Representation of a Structure by a Concentrated/Lump Mass Element
When the weight of a structure is modeled by a lumped/concentrated mass element in FEA, the location of the lump mass element is cg of the structure, which it models.
When the analysis of this model is done for inertial loadings, for linear gravity loadings, this is ok.
When the structure is subjected to rotational acceleration, the lump mass element location will not be at radius of gyration.
Thanks for your input.
RE: Representation of a Structure by a Concentrated/Lump Mass Element
Correct.
Is there a question?
(Whether a simple lumped mass model is suitable depends on the nature and purpose of the analysis.):
http://julianh72.blogspot.com
If the used lumped mass and mass moment of inertia at the CG, then this should be sufficient for both rotation and translation.
Now, it won't take any of the "accidental" torsion into effect (per ASCE7), unless the lumped mass & mass moment of inertia are offset by the % described in ASCE7.
so why not apply body forces (and model density as mass/volume) ?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - PLM and ERP: Their Respective Roles in Modern Manufacturing
Leading manufacturers are aligning their people, processes, and tools from initial product ideation through to field service. They do so by providing access to product and enterprise data in the context of each person’s domain expertise. However, it can be complicated and costly to unite engineering with the factory and supply chain. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
