Contact US
ETABS UNSTABLE WHEN LOAD INCREASED
I have applied to my model's floors a super dead load of 1.5kN/m2 as a surface load. Analysis run ok without any errors or unstable message.
When I change the superdead load of the roof floor only from 1.5 to 5.0 (rest floors 1.5 as before) then the analysis run log says that the model is unstable-ill.
Any thoughts on this? The way I am doing the change of the load s to select the floor (shell) and go to surface loads and then choose super dead case, set 5.0 and then click replace load.
Any thoughts on why the analysis run log says that the model is unstable?
RE: ETABS UNSTABLE WHEN LOAD INCREASED
Is it possible that the higher loads are causing P-delta instabilities that the lateral system can't resist?
If you run the model with the standard solver selected, then it will give you additional information on the locations of any instabilities. Also using the check model function can expose any geometry or load issues to be fixed.
As a check to see if its p-delta issues like jayrod noted, try increasing the member sizes and see if the errors go away.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
