Thin Thermal Pad to Increase Thermal Conductivity (+500C temp)
High all,
I need to increase thermal conductivity between Steel and Aluminum plates at +500C temps, using a thing semi-flexible sheet without gluing it to the surfaces of the metal plates.
Is there anything that can fit this problem?
SD
SD
RE: Thin Thermal Pad to Increase Thermal Conductivity (+500C temp)
Bergquist
Keith Cress
the melting point of pure Al is 660C, and it readily oxidizes,
you need to consider alternatives
http://www.thermon.co.za/catalogue/heat-trace/stea...
https://www.tedpella.com/technote_html/16057%20TN....
TTFN (ta ta for now)
I have used both MgO and BN for high temp heat transfer and they work fairly well.
At your temps a silicone or Krytox grease loaded with a high heat transfer filler would do the trick.
https://www.digikey.com.au/en/product-highlight/p/...
Interesting stuff, looks much easier to use than a thermal grease, do you know how well it handles differential thermal expansion?
https://www.bn.saint-gobain.com/applications/elect...
If that dosen't go hot enough then look at straight hexBN.
Wouldnt know details, maybe write to the supplier. All I know is that there are compact heat exchangers made out of graphite.
