Hydraulic modelling software that can handle zero pressure
Hi team,
I have the challenging task of commissioning a hydraulic model of a city water network that has sustained heavy damage on top of long term neglect. The context means that, for various reasons including non or semi-functioning pump stations, damaged pipes, etc., the network is not always pressurised in all sectors.
I have worked with InfoWorks some time ago, but my memory of the detailed functionality is rusty. It is my understanding that most conventional modelling software struggles with occurrences of zero pressure in the network. I have heard that perhaps Piccolo and EPANET-PDX may be software packages that can handle instances of zero pressure. Firstly, is this correct? And secondly, what about other packages? Can sophisticated software such as Bentley WaterGEMS handle zero pressure instances?
Many thanks for your advice!
RE: Hydraulic modelling software that can handle zero pressure
WASH
While they can model zero and negative pressures, they are no longer accurate, so the default is to give an error. When the pressure drops below the vapor pressure of water at the operating temperature the properties of vapor are very different. Hazen-W equations no longer apply and the coefficients on Darcy-W are very different which exceeds the design of the modeling software.
Hydrae
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Integrating the Engineering Ecosystem
Aras Innovator provides multiple options for integrating data between systems, depending on the scenario. Utilizing the right approach to meet specific business requirements is vital. These needs range from authoring tools, federating data from various and dissimilar databases, and triggering processes and workflows. Download Now
Research Report - Simulation-Driven Design for SOLIDWORKS Users
In this engineering.com research report, we discuss the rising role of simulation and the paradigm shift commonly called the democratization of simulation. In particular, we focus on how SOLIDWORKS users can take advantage of simulation-driven design through two analysis tools: SOLIDWORKS Simulation and 3DEXPERIENCE WORKS. Download Now
White Paper - Industry 4.0 and the Future of Engineering Education
With industries becoming more automated, more tech-driven and more complex, engineers need to keep their skills and knowledge up to date in order to stay on top of this wave—and to be prepared for the Industry 4.0 future. The University of Cincinnati offers two online Master of Engineering degree programs designed specifically for practicing engineers. Download Now
eBook - The Design Gridlock Manifesto
In this eBook, you’ll learn 6 ways old CAD technology slows your company down and hear how design teams have put those problems to rest. “The Design Gridlock Manifesto” shares first-hand modern CAD experiences from 15 companies around the world. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
