How to read frequency from pump curve
Four pumps in parallel with VFD control on each pump will be used for my project. total head 432 ft, required total flow 130 gpm and there is a bypass circuit to the system. the manufacturer recommended min. fluid flow of 7 gpm for each single pump. the min. demand flow rate is 10 gpm. i have attached the system curve and pump curve. if i am correct the lead pump start frequency has to be no less than 51hz. my question is how do you read from the curve the lower frequency of other pumps need to start/shutdown.
RE: How to read frequency from pump curve
Hence to start with at 10gpm with one pump that seems to be about 47.5 htz where 10GPM crosses your system curve.
ONe pump then goes up to 60htz. Then the second pump kicks in and both pumps go to about 50.5 htz (where the system curve intersects the 60 hts 1 pump line,
Same again - three pumps all start at 51 htz,
4 pumps all start at 55 htz
This is all based on all pumps getting the same frequency. Nothing else works.
On the way down the same frequency limits apply but then from say 3 pumps to 2 you go from 3 @ 51htz to 2 @ 60htz
Using VFDs for such a usage is not a good way to control pumps. Having a high head which doesn't change much for the pump range is poor.
it looks like the first pump would need to start slightly above 50 hz for 10 gpm. (round up to 51 hz as you say)
speed of one pump increases to 60 hz for 34 - 35 gpm
two pumps together start at 52 - 53 hz for 34 - 35 gpm
speed of two pumps increases to 60 hz approx 68 gpm
three pumps start together at about 54 hz 68 gpm
speed of three pumps increases to 60 hz approx 104 gpm
etc
you would leave a bit of margin for startup points.
