Section 5.8.10.3 provides calculations for estimating noise from a discharge pipe. The equation uses "L", sound pressure level, which is taken from Figure 18, and based on a pressure ratio = absolute pressure upstream of relief valve/absolute pressure downstream. The figure only shows ratios up to 10. What is the "L" value for conditions where the PR is > 10? For instance, 750 psi line venting to atmosphere, 764.7/14.7 is > 10. Is the calculation no longer valid?
