Does flow area reduce by 2/3 when sheet flow recollects to shallow concentrated flow?
I have been told that it is a rule of thumb that the sheet flow area is reduced to approximately 1/3 area when it becomes shallow concentrated flow, therefore to sheet flow velocity should be limited to 33% downstream erosive velocity.
So if max allowable velocity of a thick grass is 6fps, I should limit my sheet flow velocity to 2fps since when the sheet flow recollects it will only cover approximately 1/3 the area as shallow concentrated flow.
Agree? Do you use 33%? 40%? 50%? Why? Any links to scholarly articles or texts showing that flow will channelize to 1/3 land downstream?
RE: Does flow area reduce by 2/3 when sheet flow recollects to shallow concentrated flow?
