Reference of the Pile Skin Friction with SPT
Khurram Shehzad
Geotechnical
SA
I came across a relationship in which Pile Unit Skin Friction is calculated with SPT values as follows;
f (unit skin friction) = 3 N(spt)
I could not find the reference of it, is any body know the reference.
I dont have a reference for it. I see in Bowels that Meyerhof recommends 2 x N55 for driven piles in sand.
Regardless, I dont like calculating pile capacity by SPT. Use your SPT values to estimate a phi value in sand and gravel and nothing else.
Instead use the below for Sand and Clay
Sand
τs = Ks σ'v tan(δ);
where Ks = (1 + Ko) / 2 for Bored, CFA & Driven cast in situ piles. The value of Ks is increased by 40% for Driven precast piles
in-situ earth pressure coefficient Ko = (1-sinφ) OCR0.5
Clay
τs = αCu;
where α = 64.4Cu-0.96 (<0.85) for Bored, CFA & Driven cast in situ piles; and α = 0.5(σ'v / Cu)0.5 if Cu<σ'v or 0.5(σ'v / Cu)0.25 if Cu>σ'v for Driven precast piles
The above is form Flemming - Piling Engineering 3rd Edition
Myerhoff's Terzaghi Lecture 1976.
f-d
ípapß gordo ainÆt no madre flaca!
