For a Type 1 road base, as defined in the UK, (similar to HRs, well graded crushed) I would be comfortable giving a phi of 38 degrees. Thats assuming you have all the documentation to confirm its been placed, compacted to a good spec. But if you had all the documentation you probably would have a shear box test result....
