Mechanical operated hydraulic valve to electrical operated.
Dear All,
I have a JCB 524-50 with manual operated valves.
Now I would love to make the last valve eletrically powered.
My question is, does there excists a electric actuator which can take over the manual operation?
Or should I replace the block to do so?
See Image (https://ibb.co/c2jGSZx)
Thanks for the help,
Kind regards,
TMMJ
Kind regards,
TMMJ
RE: Mechanical operated hydraulic valve to electrical operated.
Do you have a schematic?
Do you have a valve part number or a valve stack part number?
Engineering is not the science behind building. It is the science behind not building.
5005V
V13
1S1
At the moment I don't have the schematics. But I'm also searching them.
Thanks in advance,
Kind regards,
TMJJ
When the total price for the conversion is revealed people often change their mind; electric controls are not such a good idea anyway and the manual controls work just fine.
