Hi All,
I have a small plate that is going to be in bending. It is being held by two bolts on one side. I want to see if the bolts can hold this by adding a stress concentration to the stress in these holes to see the stress on the threads. Do any of you by chance know the Kt formula to take into account the stress in the threads using the material grade of the bolts, course or fine bolt and bolt diameter?
