ANSYS Mechanical APDL - Beam Rotation
Sauljr11
IT
Hi everyone, I am new to using Mechanical APDL and am figuring out how to rotate a Beam188 element. I was able to rotate the element using an orientation node above the I-beam, as well as creating a local coordinate system. Is there is an easier and quicker way to rotate the I-beam so that its web faces a different direction?
