Contact US
How to calculate shell's hydraulic diameter of 30 degree pitch on Shell & Tube Heat Exchanger ?
Hello.. I need help because i want to calculate shell's convection coefficient. but this exchanger has 30 degree pitch tube arrangement. I've read Kern's Process Heat Transfer book and Coulson's Chemical Engineering book but they only provide for 60 degree and 90 degree pitch tube arrangement. Is thhere any formula to calculate 30 degree pitch shell's hydraulic diameter ? Also what is the source of the formula..
hydraulic diameter to calculate reynold number then to calculate convection coefficient (h). i am using kern method
Thank you so much
RE: How to calculate shell's hydraulic diameter of 30 degree pitch on Shell & Tube Heat Exchanger ?
Is the fluid under free or forced convection?
Also is the fluid being heated or cooled?
Suspect 30deg triangular pitch is essentially rotated 60deg triangular pitch. As far as i know, the rotated pattern has the same htc and dp as the non rotated pattern, as described by the Bell - Delaware method for calculating shellside htc and pressure drop, which may be found in Perry Chem Eng Handbook 7th edition pages 10-26 onwards. There is some difference though between 90deg sq pitch and 45deg sq pitch for shellside htc.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
