Contact US
shear force in concrete walls due to dead load?
I'm finding a significant amount of gravity load being transferred into my shear walls in the form of in plane shear. Is this normal?
I have my slab modeled and am applying stiffness modifiers to it. The configuration isn't something i would expect for this to occur. Is this strange?
RE: shear force in concrete walls due to dead load?
doing a little more digging, research, and experimentation it appears that these walls are acting as deep beams after a good look at the boundary conditions (how the ends of the walls are supported and the internal shears associated with deep beam behavior is being reported.
Question then is: should these in plane shears be ignored when it comes to designing to wall for lateral shear and then justify the design of the shear wall design as a deep beam for gravity loads (Design based on strut and tie model)
Thank you
Whats your mesh size?
When you've got the assign wall mesh dialogue open, are you ticking the option that goes something along the lines of "add restraints on edges"?
Maybe the wall is spanning between the returns for some reason?
See if the reactions are at every analysis node of the auto-mesh?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
