Modal Analysis of Cantilever Beam - Clamped fixture
Hi
I am trying to do a modal analysis a cantilever beam which has a total length of 36 inches. It is fixed at one end using a clamp which has a length of 1 inch. So, in my mind, the effective length that is 'free' to oscillate is 35 inches. The question is, would it be a reasonable to assume the length to be 35 inches and have it fixed by one face, or would it be more wise to use split lines and apply a fixed support over 1 inch of the beam?
RE: Modal Analysis of Cantilever Beam - Clamped fixture
Depends on how rigid your clamp is in the real world, i.e. its stiffness vs. that of your beam.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
